Is a 150 HP rotary at say 6000 rpm actually putting 300 HP to the prop (by gear reduction) if it is reduced by a PSRU by more than a factor of some 2 to 1 (down to say 2600 or less rpm) over say a conventional 2600 rpm lyconie at 150 hp direct output, straight to the prop?
So then a plane with a 300 HP design limit means one must use a 150 HP high RPM engine if it is reduced by PSRU's? (To be based then on their actual gear reduction of course)
What say ye?![Roll eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
What say ye?
