longranger
The photo below shows the aft flange of my tail spring mount as it fits against the forward side of the F-712 bulkhead. The aft fuselage is completely clecoed and drilled, and the forward flange of the mount is bolted to the aft face of the F-711 bulkhead. Do I need to shim between the mount and the F-712, or will this pull in when I mount the vertical stabilizer? The gap on the right is about 0.035, and the left is about 0.027. The bottom and center of the mount appear to be in contact with the 712 bulkhead.
I've emailed Van's support, but won't see an answer before Monday.
![FP13092013A0002M.jpg](/community/proxy.php?image=http%3A%2F%2Fwww.kitlog.com%2Fphotos%2Fproject_2052%2Ffull%2FFP13092013A0002M.jpg&hash=59e9910bfd22aea75cf0f2d038185f9e)
