Hi all-
My IO320 servo was originally installed on a Twin Commanche. The throttle and mixture arms operate opposite the normal direction, but this is easily dealt with by rotating the servo 180 degrees (discussed here: http://www.vansairforce.com/community/showthread.php?t=82736&highlight=reverse+throttle+servo). Vans brackets are nowhere close to what I need for mounting my throttle and mixture cables, so I need to make my own. 2 questions:
1. Do I necessarily need to fab this from steel? If someone has fabbed one from aluminum, what thickness?
2. What is the distance between the bracket and the middle position of the throttle/mixture arms?
I did a thorough search of the forums and did not find answers to either of these questions. Any help/pics would be greatly appreciated!
Eric
Eric
