CDBridgesRV7A
Active Member
Good Day Folks,
Well, as I was dimpling my bototm left skin for the HS, my squeezer slipped and I have a figure 8 hole. The second hole isn't even a dimple, just a hole in the skin. I checked the rivet in the dimpled hole and there is no issue with it.
Like I said above, it is on the bottom of the HS so won't be visible. Is there someway that I can fill the hole in? Is there an epoxy compound or something similar that I can put in the hole, then sand it down before I prime the interior of the skin?
I'm not worried about it. There are MANY rivets holding the skin on, however for estetics I was wondering if it can be fixed.
Chris
Chris
