mikemalone
Active Member
Building the RV7 fuel tank, I countersunk the drain valve (normal!) but made the error of dimpling the tank skin (not required and not normal!). Can the skin be left as is or will it cause any sealing problems? As usual, all suggestions much appreciated.
