David Paule
I've got the standard dimple dies, the tank dies and the substructure dies, and couldn't figure out which to use where. I finally called Cleaveland and Mike explained it to me. In case anyone else is as confused as I was, here's the guide.
Standard dies - every skin EXCEPT for the tank skins.
Tank dies - Fuel tank skins only, unless you don't have the substructure dies, in which case use the tank dies for the fuel tank substructure too.
Substructure dies - all subsurface parts like stiffeners, ribs, formers, etc., including the fuel tanks.
Hope this helps.
Dave
If I'm doing three layers, like the wingwalk area, I use the standard dies on the skins, the tank dies on the middle layer, and the substructure dies on the ribs. I don't know how necessary it is, but it works for me.
so all the substructure items have to use the substructure dies and tank dies for the tanks? I bought the die kit from Cleavland Tools and they indicated that I had all the dies I would need to build the plane.
What is the difference between the skin dies and the substructure dies?
ken
