I started to check out the TruTrak GX Pilot on one of my Phase 1 flights today and found that the display is extremely dim,,,almost to the point of being unreadable. Even moving over directly in front of the unit it was difficult to read. I can't imagine that it will be of any use to me this way. Placing my finger over the light sensor on the front of the unit does nothing. I do not have an external dimmer wired to it. There is nothing in the installation/operation's manual that addresses this. You can see where it is mounted next to the audio panel. I figure that this location is at the max 20* allowed for optimal viewing. I could also tilt it more towards the pilot side or just swap locations with the clock just left of the first G3X display. But like I stated, even direct on it is hard to read. Any suggestions would be appreciated.
