Dan you got a mixture knob on your pannel? Carb jetting problem not where to look. You may have an air leak in the system that might be leaning things out to cause the higher temps. Next consider "louvers on the bottom" for sure not the best place to install them for additional cooling. The bottom of the cowling is really a very high pressure point. Louvers installed on the lower sides of the cowling will do a much better job of moving more air out of your cowling. Install the louvers with the raised part of the louvers INSIDE your cowling holes side towards the front of the plane. This way you will not have anything sticking outside of your cowling, keeping drag to a minumim but will vent more air for you. Just my two cents worth but I've been there done that. Good luck....![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
