Jstov
My delrin canopy slider broke yesterday and I need a replacement. Is this available ready made or do I need to make one? I did not build this plane so I am not sure. If it needs to be built where is the best place to source the material? Thanks in advance!
Justin
Yes.
Yes those are in the parts list and come in the build kits. I don't have the number with me right now, but you have to just call Van's and they will be glad to send you one. Yours, R.E.A. III # 80888
And while ordering the replacement slider block I recommend you purchase a complete set of plans so that you can repair and maintain your airplane (no one should buy a completed RV without getting the plans and other build documentation with it).
They are only $10, supplied on the USB thumb drive in .PDF format.
