Would some one please tell me the degree swing of the RV-14 Rudder.
I want to install a rudder stop as I build the Vertical Stabilizer. I want to be sure it is correct before installation.
Dave
The rudder stops get adjusted based on clearance from the HS/Elevators. I test-fit mine and ended up adding the extra layer to the rudder horn contact area to get just a bit of extra clearance. I don't think you can properly adjust rudder travel without the full empennage mounted so you can check this clearance. See section 11, page 09.
