Great De-burring tool!
Are you using the maroon ScotchBrite pads or the small beige wheels?
Also, thanks/sorry to the mods for fixing my title!
Nick,
You should not use maroon [medium] discs for de-burring or final finishing. They are to rough for aluminum. The beige wheels [6", 2" and 1"] are equivilent to the maroon discs. There are also beige discs [coarse] which should only be used on steel/iron. The maroon discs are good for cleaning up rough cut aluminum, like stock cut on a band saw. The maroon discs will leave light scratches in the aluminum.
After preliminary de-burring rough cuts with a maroon disc, finish with a blue [fine] disc, to remove the fine scratches caused by the maroon disc. For de-burring of rivet holes and rib/bulkhead edges, they need only be done with a blue [fine] disc.
To answer your original question, the ultimate tool for de-burring inside of ribs [like the tail of a flap or aileron rib] is a 3" blue disc mounted on a Lisle model 22500. See
http://www.sjdiscounttools.com/lis22500.html
Also available from Sears, but over priced
http://www.sears.com/shc/s/p_10153_...ls&sName=Auto Specialty Tools&psid=YAHOOSSP01
This tool is designed to over come the stupidity of Chrysler engineers and the way they designed their newer V6 and V8 engines. Without this tool, you can not clean the old thermostat gasket off of the intake manifold.
Basically, you can also make one, if you already own a standard ScotchBrite Roloc Type R disc holder, like the one linked below.
http://www.averytools.com/prodinfo.asp?number=15410
Simply unscrew the shaft from the disc holder. Buy a 6" long, 1/4" X 20 TPI [NC] bolt and cut the head off of it. Screw it into the disc holder. Now slide a 4.5" section of 1/4" aluminum tubing over the shaft. Mount a 3" blue disc on the holder and mount the tool in your drill. Place one hand on the aluminum tube [prevents your fingers from friction burns from the shaft] and the other on the drill and you can now get into the very tightest of spaces to de-burr. The photos below don't show the tail of a rib, but do show how handy this tool is. If you own a Dodge and work on it yourself, this tool is a MUST!
The tool is designed for use with 2" diameter discs, but you can also install 3" discs on it for improved access in very tight spots. I hope this helps you.
Charlie
