CharlieWaffles
So I was looking over the Rivet Mil-Spec http://www.vansaircraft.com/public/Specs.htm specifically 3.3.1 which says "3.3.1 Cleaning mating surfaces. Before parts are riveted together, all chips, burrs and foreign material shall be removed from the mating surfaces. Burrs may be removed from rivet holes by chamfering to a depth not to exceed 10 percent of the stock thickness, or 0.032 inch, whichever is less. Disassembly after drilling and before riveting, in order to deburr faying surfaces, shall not be required."
Does that mean when we disassemble, that we dont need to debur the mating surfaces and only need to do the "outside" non-facing surfaces? To date I've "both" sides of a hole after drilling.
