D dustman Well Known Member Jan 14, 2010 #1 Hello all, I'm looking for a DAR close to Jacksonville Florida any info would be appreciated.
T Transporter Well Known Member Friend Jan 14, 2010 #2 DAR Directory The DAR list is available on the FAA website: http://www.faa.gov/other_visit/avia...gations/designee_types/media/DARDirectory.pdf Looks like a couple of guys in Jacksonville. Mike
P PCHunt Well Known Member Sponsor Jan 14, 2010 #3 (Caution: Thread Drift!) What are the "function codes" listed by each DAR? Some have only one, some have many. Which function code is required to issue an A/W Cert for an EAB aircraft?
Mel Legacy Member Mentor Jan 14, 2010 #4 PCHunt said: (Caution: Thread Drift!) What are the "function codes" listed by each DAR? Some have only one, some have many. Which function code is required to issue an A/W Cert for an EAB aircraft? Click to expand... You're looking for function code 46 for experimental amateur-built. Function code 47 for experimental light-sport, and function code 48 for special light-sport. Function code 33 for amended and replacement A/W certificates. Last edited: Jan 14, 2010
