Frank N821BF
Active Member
Did anyone find out what may have happened to his RV10? Was/is there something that other 10's should be looking at?
Frank
N821BF 9A D95
Frank
N821BF 9A D95
Why was the thread/report removed in the first place?
Mike
I'm sure it was removed due to its speculative nature and the fact that it was probably not meant for general release anyway. It was written by someone who had some unique insight into the plane and pilot.
There is little doubt in my mind that it will resurface again.....after a considerable amount of time has passed, that is.
snip...I see Tim now has it hidden behind a registration screen. Too bad....snip....I give great credit to moderators, not only here but on other boards too. I would just like to GENTLY suggest caution on removing such important messages.
I read the same report(Tims) and agree that I do not believe it was hearsay,
The posting described a low time pilot, with no high performance time, rushing to "fly off the time" in an aircraft with myriad problems with flight instruments, avionics, engine instruments and prop control. Despite much more than 40 hours having apparently being flown, no attempt had been made to rectify the most basic of snags. There were so many problems with the flight instruments, engine instruments and avionics, that even a very experienced pilot would have been hard pressed to deal with any sort of anomaly.Seems to me that information like this should be openly shared. If there is a suspected failure we should know about it. If it was pilot error we should know about it.
Sorting out all the issues on an amateur-built aircraft is serious business. Don't cut corners during the flight testing. If there is a snag, fix it. Don't simply "fly off the hours". The whole point of the required flight test program is to find all the major problems and fix them. That requires doing all the testing to identify problems, and fixing them once you have found them.
Dan,I've had this discussion with many builders that 40 hours IS required to work out all the issues with a homebuilt, especially with a first time builder.
Whenever I went for a test flight, I had a test plan in which I expected to conduct in that phase. I used the test cards someone had posted on this list and found them to be very useful and offered a good script to move you through the test phase without rushing to "fly off the hours" before it was ready for prime time.
Dan,
In reading the note that was passed along to me, there was a question regarding if he even bothered to fly off the 40 hours. I say "question" because I don't really know the truth and it is so easy to judge a dead pilot. So... Let's be careful we don't jump to judgment when we really don't know the facts.
Still, I passed along the note to my chapter's tech and first flight advisors as there was a lot of good points contained within and it prompted a lot of good discussion between our advisors.
Dan,
Sorry, I wasn't trying to slam you or anyone else. I was just trying to point out that in our tight knit flying brotherhood we have a habit to pre-judge people who make fatal mistakes.
Giving people rides before the test period is over or pencil wiping the 40 hours in a log book are a personal decision.
Like you, I elected to follow the rules and run a full 40 hour test program. However, flying those 40 hours off in one month was a real challenge and frankly was down right tiring. I was very lucky in that I had no major issues, other than loosing one week while my P-mags went back to the shop for a software upgrade.
Looking back over my log book I had one 6.1 hour day and a bunch of days with over 4 hours of flight testing. That is a LOT of flying, more so when you realize I was taking my cowling off between flights and inspecting the engine on those days. It just goes to show you, build 'em right and they won't give you any problems.
Should there be a standard transition training syllabus and flight regimen. I have heard -- anecdotally, of course -- that the most oft mentioned transition training folks have different points of view on flying an RV. Should there be one?
Hi Bob/others,
the EAA let us know that in 2001 there were 340 something first flight fatalities. Last year, since we were allowed to charge for training/renting our RV's and others (lancairs, Glasairs,etc), first flight fatalities dropped to 45 or so....
340 first flight fatalities in one year?!
I find that very hard to believe....even 45 first flight fatalities in one year is difficult to comprehend.
I hope this is not the case.
This is a good time to put in a plug for DARs. Most DARs will give you a very thorough inspection well beyond what is required. For example, my inspection checklist is 7 1/2 pages long. The checklist typically used by an FAA inspector is 1 page.You (anyone that hasn't finished their plane yet) should realize that the DAR/inspectors function is not to make sure that you build your plane correctly or that it is safe to fly. They are there to make sure that the paper work is in order and that the plane conforms with the FAR's. This will include placards, minimum equipment, W&B, etc. If the inspector helps you find missing rivets or other builder mistakes then they are doing you a favor. I think that most inspectors try to help you out this way, but it is going beyond what is required.![]()
The 340 number is real but it was total fatalities in experimental aircraft for the year 2000, not just first flights, However, the majority of those deaths were within the first 10 hours on the aircraft. The important fact is that the number was cut through access to training.
John Clark ATP, CFI
FAAST Team Representative
RV8 N18U "Sunshine"
KSBA
By that measure, Exemption 7162 was an unqualified success as it contributed to a dramatic reduction in fatal experimental aircraft accidents - from 340 in fiscal year 2000 to 49 in fiscal year 2006.
QUOTE]
This makes more sense Pierre - I think what surprised me with your first post was that you said 49 "first flight" accidents (or maybe I was too tired and read it wrong). I can buy (although I do not like or accept!) 49 Experimental fatals in a year - but if it were 4 during first flights, I'd recommend zero-zero ejection seats for everyone!![]()
No more legal transition training?
I just took a look at the NTSB website. The accident information is in the 2000 & 2001 GA Accident Aircraft Data used in Annual Report links on this page:
http://www.ntsb.gov/aviation/Stats.htm
I sorted these files down to fatal amateur/experimental accidents and found 50 crashes in 2000 with 72 fatalities. In 2001, there were 56 crashes with 71 fatalities.
These are not good numbers, but I'm curious as to where the 340 number came from? Was that a 5 year total? No telling.
