ArVeeNiner
I posted this on the Dynon forum and didn't get much feedback. Does anybody have a solution? BTW, I use only 100LL fuel:
Hello:
I've been flying with this issue since my first flight in 2012 and I was wondering if there has been any resolution to this.
I have calibrated several times and each time I get the "there was no change in the voltage reading" warning. This is due to the very small change the Dynon sees during calibration.
As a result, my fuel gauges on the D-180 are accurate towards full but are significantly off near empty. They indicate that I have a couple of gallons more fuel than I really have. Not a good thing.
I finally got tired of re-calibrating the tanks and have accepted the issue. However, it's very disappointing that the reason I went with the capacitive set up is for improved accuracy. I would have been better off installing floats.
I bought the converters from Dynon years ago and the capacitive plates in the tank from Vans. I'm flying an RV-9A.
Has there been any solution to this issue?
Hello:
