Paul Tuttle
Over the last few flights the ammeter on the D-120 has been fluctuating between -30 and +6. It will stabilize for a while and then do it again. The volts seem to stay around +14 while this is going on and all else seems normal. No smoke, no fire. ![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I checked for loose wires or connectors and checked the continuity of the wires between the d-sub and the shunt. Everything appears to be ok and I'm not sure where to look next
If anyone has some helpful advice, I'd appreciate it.
Thanks.
Thanks.
