dreed
Hi All
Adding an IFD540 to my panel soon and looking for tips on cutting the hold in the secondary bulkhead behind the panel (RV-7A Slider) for the long tray.
Why re-invent the wheel with all the smart folks on here... right?
I plan on four holes in the corners, but then a saw? Nibbler? Anything better?
Thought about clamping a piece of wood in there to dampen vibrations if I go the saw route.
Thanks in advance-
dan
10 years ago I used a nibbler which sprayed tiny chunks of metal everywhere.
Today I'd use an OMT -- oscillating multi tool with a curved-tooth bimetal blade. And definitely drill holes in the corners first.
This style blade: https://www.amazon.com/Bosch-OSL114F-3-Starlock-Oscillating-Bi-Metal/dp/B01DDA7VU0
Or this one: https://www.amazon.com/Bosch-OSL312T-Starlock-Oscillating-Segmented/dp/B01DDA7VV4
We called a Multi tool a "Wig-Wag" in the plumbing business, and the best blades you can buy are Diablo Carbide:
https://www.amazon.com/s?k=diablo+c...diablo+ca,tools,149&ref=nb_sb_ss_ts-doa-p_6_9
Something fine toothed makes the smoothest cuts.
-Marc
Used my Dremel. It's my first choice for most things, but I'm a dentist, so I'm biased!
Stewart Willoughby, 6 final assembly
