Mitch757
Sponsor
What's the best method to cut the 2 inch hole in the firewall for the heater box.
I have the 2 1/4 inch knockout punch but that leaves little edge distance.
Suggestions?
Mitch
I don't think it has to be a perfect circle.
I just used a Dremel tool and it went pretty easy.
Suggestions?
Mitch
If you search the threads you'll see a number of suggestions. I used a 2" bimetal hole saw that worked just fine.
Good luck.
2? hole
I cut mine with a 2? hole saw in a drill. Had a helper back it up with a wood block. Used a dremel with a sanding drum to smooth up the cut edge.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
