Hello, I'm new to the forum and need help and some hand holding. After four years and a million rivets , I just hung the engine on my 9-A. Probably should have built a glider, since all I do now is sit and stare at it. Rivets I understand, motors I don't. My engine is a new D1A that I want to convert to fixed pitch. Should I remove the prop governor as well as the oil line? If so, should I order the accessory case cover and gasket that Vans lists? Can someone give me step by step instruction and a little confidence before I begin Lycoming Service Instruction 1435? Any enlightenment would be great. Ed
