Good morning, afternoon or evening,
I have been reading many of the posts re lean of peak operations, and considering the various arguments for & against while studying Figure 3-1 in our Lycoming Operators manual - 'Representative Effect of Fuel/Air ratio on .... and Specific Fuel Consumption at Constant RPM & Manifold Pressure'.
Our copy of Fig 3-1 illustrates that:
a. at Lycoming's 'Max Power Range' between EGTs 100 & 200 deg F Rich of Peak (ROP), percent of best power is relatively flat and at about 100% of 'Best Power'.
b. at Lycoming's 'Best Economy Range', leaned to peak EGT, percent of best power has dropped aprox 5% from 'Best Power'.
c. leaned to aprox 50 deg F Lean of Peak (LOP), percent of best power has dropped aprox 8% from 'Best Power'.
d. leaned to aprox 90 deg F LOP, percent of best power has dropped aprox 16% from 'Best power'.
e. if you lean further, then the drop in power becomes much steeper.
f. the specific fuel consumption (SFC) curve is minimum and flat from peak to 90 deg F LOP EGT, and SFC increases either side of Lycoming's 'Best Economy Range'.
Generally when I was recording cruise data for our RV-7, I chose peak EGT as a setting to maximise repeatability of the data. However, I have been experimenting with LOP cruise (below 75% max power, and no leaner than 30 deg C/ 50 deg F LOP).
I have now plotted fuel flow against observed airspeed (call it KIAS), differentiating as to whether I was at peak or LOP. The two curves are the same shape, but the LOP curve is showing:
a. about 3 litres per hour (aprox 0.8 USG/Hr) less fuel flow than the peak EGT curve at about Carson's Speed (aprox 105KIAS at 816kg/1800lb AUW), and
b. about 2 litres per hour (0.53 USG) less fuel flow at about 150 KIAS.
If valid, this data shows a clear benefit in operating LOP, eg, at 105KIAS, fuel flow is about:
a. 19 Litres per hour (5 USG/Hr) at Peak EGT, and
b. 16 Litres per hour (4.3 USG/Hr) LOP.
For comparison, at about 150 KIAS, fuel flow is about:
a. 38 Litres per hour (10 USG/Hr) at Peak EGT, and
b. 36 Litres per hour (9.5 USG/Hr) LOP.
Given the curves illustrated in Lycoming Fig 3-1, I was surprised at the result. I expected that LOP would have resulted in a lower KIAS for the same fuel flow because of the power reduction resulting from leaning below 'Max Range Power'.
The caveats on the data and result include the following:
a. the curve for peak EGT is faired to data with much less scatter than the curve for LOP data (but all LOP data is below the curve for peak EGT).
b. all data as observed on the Dynon D100 EFIS and D120 EMS - no calibration - and no correction for pressure, temp, weight, etc.
c. the data were recorded on many different days and conditions over a 18 month period, but on those days, data was either peak or LOP.
d. the pilot is now referred to as an 'older gentleman' on buses and trains, & often offered a seat by people who appear to me old enough to be my parents, but younger than my grandfather's image I see in the mirror when I am shaving, so residual competence in data collection & analysis could be an issue.
Aircraft is a standard RV-7, tip up, Aerosport IO-360M1, standard compression, ECI components, E/PMag combo, A curve advance (jumper fitted), NGK BR8EIX auto plugs, Hartzell BA constant speed, basic weight 492kg/1085lb, empty CofG 78.24 inches aft of datum, painted and complete.
I would be interested to hear if other people have noticed a similar result, and even more interested in a rational explanation for the benefit of operating LOP given my expectations based on Lycoming figure 3-1. If you use senility to explain the anomaly, I will feel aggrieved, but the offer of a fine ale would compensate my bruised ego.
Best regards
Best regards
