DakotaHawk
With only 1.8 hours left to fly to complete my Phase 1 restrictions, I headed out to the airport today to get some stick time in. Turns out the wind was blowing 12kts @ 280. Normally, I would take the smaller and less used RWY 29 to get in the air. But today, seems every Cub, Light Sport, Gliders and Pawnee tow plane, Bonanza, and Gulf Stream were out practicing crosswind techniques on RWY 34. Soooo.....
Not to spoil the traffic pattern, I decided it was really time (since I'm still in Phase 1
) to work on cross wind landings and pattern work. I've always been hesitant about crosswinds because my other plane is so light and has huge wings - it really gets pushed around! So my 300 hours of flying includes very little crosswind experience.
What did I learn???
The RV has no problem dealing with a 10kt crosswind component. Full flaps and three point landings are still OK. Maybe a little more crosswind and I would have had to do wheel landings instead.
When sharing the pattern with a couple of Cubs, Light Sports, and other non-RV type airplanes, get used to putting on the brakes and doing 80mph on downwind!
For some reason, Light Sports like to extend their downwind about a mile beyond the numbers! Politely ask for permission to cut a shorter base leg to prevent ending up making your base leg over the next airport's pattern!![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Constant Speed props are great when you need to slow down now
What did I learn???
