Well this is my first post in these forums so I'll start off by introducing myself. I started construction of an RV-7A a couple months ago in a dilapidated outbuilding -- half of it with no floor at all (just gravel) and the rest of it with a wobbly uneven wooden floor. Eventually I hope to be able to persuade my wife to let me move into the garage but for now this outbuilding will have to do.
I'm by no means a handyman, have no prior experience and before this project had essentially no tools other than a hammer, pliers, and a couple of screwdrivers. But the salesman at Van's said, "No problem."![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I haven't updated my blog in a while but you can read more about my project there.
Now for my problem: I'm currently working on the horizontal stabilizer (drawing 3). Per p. 6-3 of the instructions, I cleco'd/clamped the ribs HS-404, HS-405, HS-702 front spar, and HS-710 and HS-714 reinforcement angles and made sure all were pulled up tight. I don't have an angle drill so I used a 6" drill bit (the instructions say an angle drill is preferred "but a long drill will also work").
The problem is I couldn't drill those holes perpendicular to the materials. Two of the holes are through relatively thin aluminum and I'm not too worried (should I be?). The other two include the reinforcement angles and as a result the rivets are going to be crooked.
I've done only the left side only so far. I'm terrified to proceed and am not sure how best to do the right side (ugh, buy an angle drill?).
Here are pictures. Click on them for larger views. For the photos I've removed the nose rib HS-404 and just pushed a rivet into the hole so you can better see what I'm talking about.
Advice appreciated, not only how to deal with the crooked holes I've already drilled, but how best to proceed on the right side (preferably without having to buy an angle drill, but I will if I have to).
--Shannon Miller
RV-7A Emp.
--Shannon Miller
RV-7A Emp.
