lorne green
Tonight I learned a lesson. Many of us know of the wonderful properties of crazy glue (cyanoacrylates). Well, I needed
to slip 10L washers on either side of the elevator belcrank push-rod bearing on my 7. Because this is in a tight area, I dragged out my crazy glue to apply the smallest amount of cyanoacrylate to the left and right of the bearing prior to bolting to the belcrank....but remember I must maintain perfect washer alignment for the bolt travel. I slid the bolt in to the bearing with the washers in place and carefully placed a drop of glue where the washers meet the bearing. Holding it there for just a few seconds and wahl-la (as they say in Quebec) I have bonded the bolt and washers to the bearing centre
No amount of tugging on this would release it so pulled out my air rivet gun and gave it a shot. It released easily using that technique. Thankfully, no damage to the nylon within the center of the bearing...it rotates normaly. In the future, in tight areas like this, I going to employ the thin wire method of "threading" washers or some simular method.![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
