Phil
special notice to pilots in the central Texas area
==> ATTENTION PILOTS <==
FAA TO ESTABLISH TFR OVER BUSH RANCH WEDNESDAY THROUGH MONDAY AOPA is sending this message to advise pilots in the Crawford, Texas, area that the FAA has issued a notam that will expand Prohibited Area P-49, from Wednesday, August 22, through Monday, August 27, for President Bush's visit to his ranch.
There will be a 30-nautical-mile-radius temporary flight restriction
(TFR) centered on the ACT VOR's 241-degree radial at 14.4 miles, extending up to Flight Level 180. It will be in effect from 1:50 p.m.
local on Wednesday through 11:25 a.m. local on Monday. There will be a smaller 10-nm-radius GA no-fly zone in effect within the larger TFR.
A 4-nm-radius cutout will be centered on the GRK VOR's 057-degree radial at 7.3 miles to allow operations at Skylark Field (ILE). See AOPA Online for the full text of the notam along with a graphical depiction ( http://www.aopa.org/whatsnew/notams.html#7/4016 ).
The affected landing facilities are Flying Nd Ranch (22TS), Valley Mills Municipal (9F1), Scott (31TX), Wildcat Canyon (3T8), McGregor Executive (PWG), Clifton Municipal/Isenhower Field (7F7), Waco Regional (ACT), Tigerbird Field (2TS3), Gatesville Municipal (GOP), Womack Farm (75TE), Parrish Airstrip (TX52), Heathrow (TE17), Lake Whitney State Park (F50), Sheriff Department Heliport (TA04), Flying Heart Ranch (70TE), Square K (40TS), Tstc Waco (CNW), Draughon-Miller Central Texas Regional (TPL), Wings For Christ International Flight Academy (73F), Hood AAF (HLR), and Barnstormer (TE99).
The FAA also has issued notams establishing a TFR over Waco for the president's arrival and departure from his ranch. There will be a 6-nm-radius TFR centered on the ACT VOR's 089-degree radial at 10.1 miles, extending up to 3,000 feet agl.
The effective times are 1:50 p.m. local until 3 p.m. local on Wednesday ( http://www.aopa.org/whatsnew/notams.html#7/4017 ), and 10:20 a.m. local until 11:25 a.m. local on Monday ( http://www.aopa.org/whatsnew/notams.html#7/4018 ).
The affected landing facilities are Tstc Waco (CNW) and Wings For Christ International Flight Academy (73F).
Because TFR airspace frequently changes, AOPA strongly encourages pilots to obtain a briefing and CHECK NOTAMS before every flight.
TFR violators will be intercepted and forced to land.
==> HELPFUL WEB LINKS <==
AOPA's Real-Time Flight Planner provides graphical depictions of TFRs ( http://www.aopa.org/flight_planner/ ).
Check the FAA's TFR Web site ( http://tfr.faa.gov ).
Download the AOPA Air Safety Foundation's intercept procedures card ( http://download.aopa.org/epilot/2003/intercept.pdf )or review ASF's "Know Before You Go" program ( http://www.aopa.org/asf/know_before/ ).
==> MAKE SURE YOU'RE PROTECTED <==
SIGN UP FOR AOPA'S LEGAL SERVICES PLAN
Because of the heavy call volume from members and the changing climate for FAA regulations and increased vigilance, we want to remind you to consider the AOPA Legal Services Plan protection. For more information or to start your coverage immediately, call 800/USA-AOPA or visit AOPA Online ( http://www.aopa.org/info/legalservices7/ ).
==> CONTACTING AOPA <==
* If you have additional questions about TFRs or any other *
* airspace or aviation matter, contact our AOPA Pilot Information *
* Center at 800/USA-AOPA. You can also reach us via e-mail *
* ( mailto
[email protected] ). *
Having difficulty using this service?
Contact ( mailto:[email protected] ).
AOPA, 421 Aviation Way, Frederick, Maryland 21701.
Telephone: 800/USA-AOPA or 301/695-2000 Copyright (c) 2007. Aircraft Owners and Pilots Association.
* ( mailto
