Anyone have experience with having an o-ring groove cut in their crankcase split line flange lately? Haven't heard much about this mod in the last 8-10 years. Would you do it again?
Correction - Div-Co does not do this. Ly-Con does...
I understand the downside - one-way mod, removes material from the crankcase flange...
Any actual experience and observations would be much appreciated, as I have a case being worked currently. Note - I'm looking for actual experience - good and bad - with a possible improvement modification so I can personally determine if the cost is worth the benefit. Not opinions on why it shouldn't be done.
Thanks!
Thanks!
