Doug94
I went out to the hanger today to prep my -8- for a trip this weekend and found four cracks in my aluminum spinner. No prop strike, no binding in spinner connections just cracks. Anyone have any assumptions on how this happens or had this happen? I have about 100 hours on this spinner (the original Vans fiberglass spinner is going back on). I'll be contacting Cummins tomorrow.
Two cracks began in the blade cutouts and extend into the body of the spinner about 2 inches, two other cracks are small and began from a screw hole in the base plate.
I'd past a picture but I'm non-tech savy
Have you had the prop dynamically balanced?
FWIW, it's not uncommon for certified spinners to do the same thing. Yet another reason I'm glad I can use a non-certified fiberglass spinner...
Charlie
cracked spinner
From my past experience (non RV) of 3 cracked aluminum spinners, HAVE THE PROP DYNAMICALLY BALANCED ! Just my opinion.
Gary
Hi Doug. Could you please email me a picture of the cracks in your spinner? I have a Cummins spinner as well and am curious what you see.
lschneider39 at cox.net and if you want I will add the picture to the thread on your behalf. Thanks, Larry
Here is a picture of the crack posted for Doug
[/IMG]
[/IMG]
