rv7charlie
Just took delivery on a used (ebay) CP-214 squeezer. I tried a 3/32 dimple & it worked, but didn't seem to do it with a lot of 'authority'.
Put flat squeezer dies in it & tried a 1/8" rivet. It wouldn't even deform the rivet enough to keep it in the hole. No squeeze at all. There are no obvious bad leaks, compressor is at just under 120 lbs, the stroke seems smooth without any hanging, the trigger is depressing the valve plunger to flush with the frame.
Is there an obvious, easy fix I'm overlooking, or do I need to complain to the seller?
Charlie
Charlie
