Bayou Bert
Cowling stuff, man oh man.
I am no fiberglass guru, don't even like cutting it, like most.
I am not sure exactly how to fix the mis-alignment of my cowling.
I have made the first cut on the bottom across the intakes to see
where and what. I dressed up the over lap at spinner to make it
fit best. I put clecos on side of spinner and two temps in front,
just to get it to fit as you see it.
I have no clue how to get rid of the offset. I cut some 2x4's the height
of my firewall and have them on the inside for spacing so everything
is square.
I can not get the bottom of cowling to overlap the top, just won't go.
This shot is to show the overall cowling clecoed together at the front with
the boards inside.
This shot is a little closer showing the mis-alignment both sides
This is a close up showing the left side alignment
Once again, any and all recommendations appreciated
is square.
the boards inside.
