Per drawing #26 (full side view) it appears the center line runs from spinner tip parallel to the upper longerons. From the top left dimensions on that drawing (4 3/4" + 1 5/8") it should be 6 3/8" below the longerons.
However on drawing #43, Installing and Aligning Cowl Cheek Extensions, it appears to be approx 7 1/2".
What gives?
Is the tip of the extension supposed to be slanted 1 1/8" down?
Finn
What gives?
Finn
