OK, I researched this and found nothing. How do you fit/install the lower cowling on an A model with a 3 blade prop? I have cut the slot in the lower cowling for the nose gear 14 inches long. Do I need to make the slot longer?
One of Van's RVator newsletters has an article on cowl mods for easy on/off if your installing a three blade prop.
Reiley, any clue as to the year, maybe even the month, that this article appeared?
Regarding covering up the nosegear slot in the cowl for a three blade. Bob at Fairings-Etc makes a really nice nosegear fairing that extends both forward and rearward to cover the slot completely. I have one on my 6A with a Catto three blade and it works and looks great. Check it out here...
.....http://www.fairings-etc.com/
Regards,
We have an IO-360 with a MT 3 blade prop, and this was a major headache working the lower cowl.
3. Use the fairing from Bob at Fairings etc, and once installed, you can see how far back you can cut the slot. Unfortunately, you can't properly determine this until you've installed the nose gear fairings. However, you can come close, just leave a little fudge factor. If I remember correctly, you can go at least another 1 1/2" more than the plan shows if you are going to use Bob's fairings. Every little bit helps.
We have the vertical induction.Just to clarify...If this is an IO360 with horizontal induction using the snorkel, it does not require as long of a slot as an O-360 with an MA4-5 carb. The vertical induction O-360 cowl has a very deep induction scoop. Because of this, it comes down lower on the gear leg than any of the other cowl models will.
With have the vertical induction.
The induction system doesn't seem to figure in the problem.
Sorry ScottYou're right. It's not the induction system that matters, I said it was the different cowls for the different induction systems. I have worked with RV's that have all of the different cowls and have found that it does make a difference...but everyone is entitled to there own opinion![]()
I doubt if Bobs fairing will cover the opening required for many of the three blade prop installations.
I was the first person to install a three blade on an RV-6A (1992). You need a slot length that allows for easy removal and installation. Don't make it difficult or you will be making a mess of your paint after a while.
Sorry Scott, but I must respectfully disagree. My installation, O320, 6A, Catto three blade, has not been a problem. I do place a couple layers of masking tape on the forward surface of the nosegear leg during cowl removal, and I know the proper removal angles to get that lower cowl off with no problems and the Fairings-Etc nosegear fairing I referred to covers the required slot in the cowl with room to even extend the slot further forward if I so desire.
