My RV7A cowling is rough trimmed. I'm using Van's standard hinge method to join the top cowl to the bottom. With baffles installed, and all cowling parts assembled with clecos, the gap top to bottom on both sides, runs from flush to apx. 3/32".
What is an acceptable gap? If I wanted to fill in the gap, how would I do it? Is it best to just live with the gap as long as it is uniform front to back?
Also, the gap between the front face of the cowl to the prop back plate is not uniform. From apx. 1/4", on top to 1/2" between 3 and 8 o'clock. I realize this is not uncommon, but it looks bad, so how do you fix it?
The top to bottom fit in both air inlet ducts is not good and will need reshaping and gaps filled. Again, what is the best way?
Thanks for your help,
Mike
Mike
