We recently changed the adjustable receptacles for our cowling fasteners to a much better design. The older style receptacle cage was made of thin aluminum with small tabs bent around the receptacle body to retain it. This cage allowed the standard 1/16? float fore and aft but, much more side to side. Over time in the field, the tabs were sometimes bent back open by pressure exerted on the fastener when engaging the mechanism. This can lead to the receptacle body becoming loose or a possible failure of the system.
We now use a fully enclosed cage to encapsulate the adjustable receptacle body (original Camloc? style). It allows an industry standard 1/16? float in any direction which is enough to provide relief for minor misalignment from stud to receptacle but, not so much that it allows excessive shifting of the panel. In addition this configuration positively and permanently retains the receptacle body and allows us to offer the receptacles in a variety of materials. (Zinc Plated Steel, Aluminum or Stainless). Also, we are using a metal anti-lock pin for the initial depth adjustment. This pin can be re-installed after the initial fitting so that if further adjustment is required later, a separate pick tool is not necessary.
Late last year we also updated the fasteners themselves to make them stronger and the heads tougher when engaging the screwdriver to prevent stripping / galling. If anyone who participated in our previous group buys wants to swap out the older style components with the updated versions just let me know.
Best Regards,
Jeremy Summers
MilSpec Products, Inc.
T. 352-735-0065
www.milspecproducts.com
![NewCageOldCage.jpg](/community/proxy.php?image=http%3A%2F%2Fwww.milspecproducts.com%2Fimages%2Forig_images%2FNewCageOldCage.jpg&hash=21825133db7c399eae5f5cdf510ae3f0)
![40S5GmtX.jpg](/community/proxy.php?image=http%3A%2F%2Fwww.milspecproducts.com%2Fimages%2Forig_images%2F40S5GmtX.jpg&hash=f2ee72e445a482186617286f8fa96080)
Best Regards,
Jeremy Summers
T. 352-735-0065
