Tony Petrone
Member
Does anyone have a easy way to put the top cowling pins in at the firewall.I can hardly fit my hand through the oil .
Years ago, (25 or 26-years) I made a slot and cover plate to get the top firewall cowl pins out without using the oil check / fill door. The cover plate has stops to keep the hinge pins from coming out and is held to the metal on the airplane with two #4 screws and platenuts.
