I was wondering for those of you that have attached and fitted your cowling, did you have any issues with the hinge on the right side? My hinge is 21 ⅞" per the drawing and the pilot hole is 23/32" from the end per plans. However, the first eyelet is in the way once you get the pin inserted, so you can't bend it around the clasp on the firewall. It also looks like it is too short on the end by the motor mount. I have triple checked my measurements. Thanks.
