rv8or
RV8 Builders
Looking at the shims for the piano hinges on the firewall
What thickness did people use?
Sides
Bottom
Just trying to get a starting point.
Thanks, in anticipation.
Rob
Shims
Mine is a 7A with Skybolts but the concept is similar. I used .032". However, I added a strip of carbon fiber and a strip of fiberglass over it. That's about .020" thickness of stiffener material. Without the added material, I would use .025". Even if its slightly shy, the micro, primer and paint will take up the difference.
followed the instructions but..
I followed the plans but the top hinge is curved and uses a smaller rod to go through the curves. this makes the cowl loose at the top. If I did it again, I would increase the shim thickness where the piano hinge flattens out at the top to keep the cowl tighter to the top skin/firewall.
