After trimming my cowl, I don't have enough cowl lip/edge area for the leaf of the piano hinge to lay flat on just the fiberglass without being partly on the honeycomb. This makes the leaf lay at an angle and the thickness is of course greater. Should I grind the honeycomb away so the leaf of the hinge will lay flat and how would I seal the edge of the honeycomb?
Thanks, Rich
Thanks, Rich
