Fitting the cowl and I have an issue on the left side the cowl is not symmetrical and when I make my horizontal cut, which needs to be perfect lol, I will end up taking more off of the left side. This is not a major deal and expected I have the cowl centered and level. The issue I will run into is after the cut I will be an 1/8" away from the honeycomb structure in the cowl this will put my Skybolt fasteners in a bad spot. Do i need to remove all the honeycomb that will interfere with this? its almost like they put the honey comb 1/2 offset to the left.
