Started the engine at 0634 this morning and by 07:20 the testing was done. The results were disappointing as they often are. The test was flown at 6,000 ft density altitude the local altimeter setting before takeoff was 30.03 and after landing it was 30.05 so descending air negative effect on airspeed (ref. Mark Frederick). At 6,000 the temperature was 7C so the test was flown at 5,600 ft to get the 6,000 ft density altitude. The RPM = 2720; MP=24; OT and OP not recorded; CHT 1=296, 2=344, 3=343, 4=316; EGT 1=1227, 2=1357, 3=1338, 4=1307.
The GPS track speeds were:
360 = 146, 146, 146, 146, 145 = 145.8 avg
120 = 199, 200, 198, 199, 200 = 199.2 avg
240 = 194, 194, 194, 194, 194 = 194.0 avg
NTPS Spreadsheet
Wind = 35.7 kts
Wind direrction = 355.6
speed =
181.4 kts
My conclusion is the change provided no increase in racing speed over taping the same holes. The only advantage is the the covers will not blow off.
Bob Axsom
