S Surfdoc Member Sep 25, 2018 #1 Quick question: I am in the process of countersinking the spar for the plate nuts. Should I be using a drill bit lubricant such as Boelube or nothing at all while doing so? Thank you ahead of time for the guidance!
P PilotjohnS Well Known Member Sep 25, 2018 #3 Just me I only lubricated drills when used in steel or when called out in directions
V Vlad Well Known Member Sep 25, 2018 #4 No need for any lubricant. Keep that countersink cage under control and enjoy drilling.
