JohnAdams
I'm New Here
The RV-7QB roll bar and associated tubes are powder coated on the exterior. However, inside the tubes appears to be bare shiny metal. Anybody coating these with primer? Seems difficult without messing up the powder coating. I heard a suggestion to simply coat with oil.
Thanks. for your input.
roll bar corrosion
Oil... hot day... oil starts creeping out onto your paint and into the interior of the plane... messy.
Mark Andrews N598X
Corrosion X.
Perfect solution for the roll bar.
Perfect for corrosion prevention.
Perfect for leaving a black, sticky mess in the cockpit, and will seep for YEARS!
Everything in life is a compromise! :D
Dave
