AntiGravity
I've now all but finished riveting the RV-8 fuselage together. Just fitted the seatback support frame. Next step is to flip the fuselage (again), and fit the undercariage. So, in preparation, I went and got my Grove airfoil gear legs down from storage and SHOCK, HORROR. Aaarrrgggghhhh! That looks like corrosion to me, though admittedly I don't know what it should look like (corrosion that is, I know what the gear legs should look like!)
Help! Guys, what's the best way to remove this corrosion; just go at it with 1000grit emery, scotchbrite pad, chemicals, what?
I'm planning on having the legs polished, but the bits that are hidden by the fuselage attachments and fairings will be primered. I want to primer those bits and then drop the legs off at the polishers. When I get them back, what's the best way to treat them to prevent more corrosion in future? Oh, and is there anything I need to discuss with the polishers in the way of special requirements? They made a good job of my motorcycle bits and pieces one time, but these legs are expensive and I'll be relying on them over and over!!
Poor(-ish) photo in my kitlog here...
http://www.mykitlog.com/users/display_log.php?user=jpreou&project=45&category=0&log=45282&row=1
Thanks in advance.
Thanks in advance.
