RV7Ron
I have a question for the guys that are priming interior parts. Here is a situation that I'm sure I'm not the only one that is experiencing and I need some guidance from some wise old veterans.
I match drill parts, disassemble and prime with a two part epoxy. Cleco it back together and get ready to set rivets...but low and behold the primer thickness has now closed up my hole slightly and I cant get a rivet into the hole. No problem, grab a drill and ream the hole. I have now removed my primer in the hole. Should I re-primer this before setting a rivet or am I good to go skipping that? Can I assume that the rivet hole/rivet will be a moisture-free environment or is this going to corrode later? This has been bugging me and I didnt find anything in AC43-13 referencing this specifically.
