Hello,
I have an RV-10 and the best that I can tell I have Cleveland brake parts. (Def not Matco)
In fact, I've replaced my liners with #66-105 liners which are for Cleveland calipers.
The new brake disk I had ordered is part number RA164-07500. With the wheel off and on my bench, I compared the existing disk with the new disk. It all looks the same except the existing disk is taller (by about 1/4") than the new. I did not try the new disk because I believe that, it being shorter, would put the braking disk's surface closer to the inside of the wheel, hence, the outboard part (back-plate) of the caliper in contact inboard side of the wheel.
Does any one happen to know the proper disk part number for this?
Unfortunately, there are no log-book entires for past replacements that I can key my search from.
