And the answer is ...
I got up at 5:23 this morning dressed in the dark and drove to the airport to complete the final test to determine whether a baffle in the front end of the lower cowl is of any value for increasing the speed of the airplane. Yesterday I removed the baffle under test and closed everything back up - all that I had to do was pull the plane out of the hangar and fly the test. When I got to the airport it was very dark and no one else was present. I opened the hangar door and got back in my 1986 Dodge Power Ram compact pickup truck to stay warm while I waited for the sun to come up. At 7 o'clock I could see the sky and it was covered with a low broken layer so I closed the hangar door and went home for breakfast of tea, oat bran and toast with no butter with no test results. As the day went on the sky cleared to that beautiful blue that we all know and love. The day had started and my next oportunity to fly the test would come after getting cleaned up and dressed again, completing our daily walk in the park and buying our weekly groceries - retired life may not be exciting but it is satisfying to me.
At 14:57 I was back in the airplane turning the key to start the action. Once again the flight conditions were far from perfect. The surface wind was from 260 degrees at 19 gusting to 23 with runway 34 active the altimeter was 29.82. The altimeter setting for the two tests flown the day before yesterday were 29.94 and 29.92 respectively so an opinion could be had that the trend is downward indicating a rising air mass and each test, all things being equal, would produce a higher speed (reference Mark Frederick's - F1 and EVO Rocket Man - earlier post in this thread) than if the air mass was vertically static. After takeoff I turned to 090 and climbed to the east. The initial rate of climb was unusually high, 2000 ft/min as opposed to my usual 1,500 ft/min which is consistent with the rising air theory - just an observation.
At 6,000 ft pressure altitude the OAT was was 0.0 C so the 6,000 ft density altitude test was flown at 6,300 ft with the altimeter set at 29.92 per the
www.us-airrace.org handicap procedure as approved by ATC.
Recorded data:
MAP 23.7
Oil Temp 160
Oil Press 85
CHT 1=294, 2=329, 3=331, 4=310
EGT 1=1306, 2=1409, 3=1391, 4=1354
360 Track speeds 175, 177, 176, 175, 172
120 Track speeds 208, 209, 209, 211, 211
240 Track speeds 162, 159, 161, 160, 159
Engine run time 43 minutes
Fuel burn 6.852 gallons
Fuel cost $24.94
I plugged the average speed for each track into the NTPS spreadsheet and it revealed to me the True Air Speed for this test was
183.3 kts and the wind was 283.2 degrees at 27.6 kts. This is not only faster than any of the tests with the new test baffle installed in the front of the lower cowl, it is 0.7 kt faster than any previous test.
From all of this testing I conclude adding a baffle to the front of the lower cowl, in an effort to eliminate blowback of the cooling air out of the front of the cowl, does not result in a faster airplane. Here is a point that should not be overlooked - adding the baffle produced a change in speed (slower) and that is significant. If one knew why the change occurred perhaps there is a concurrent modification that would result in a speed gain - like the horizontal baffles and the rear lower cowl baffles that worked for a net gain of 4 kts after the rear baffles alone had reduced the speed by 2 kts (6kt difference). For now the lower cowl forward baffle components have joined their cousins on the shelf of offerings to the God of Speed (ref. quote of New Zealand's Burt Munro in the movie "The World's Fastest Indian").
I guess I can think about that deflector in front of Cylinder 1 now.
Bob Axsom
