Garland Edwards
Member
Fellow Builders,
I have been looking for a marking tool to lable parts with sequence numbers or part numbers.
I ran across this cool tool on Harbor Freight: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?function=Search
I ordered one and received it today. As advertised, it is as small as a fountain pen, has a diamond tip cutter, and will mark on aluminum, hardened steel and glass. The mark that it leaves is so slight that there is no worry about cutting too deep and causing a stress crack source. It also came with an allen wrench to change the rotary tip and the two batteries.
I have a scribe and also a portable Dermal tool, but this tool is handy.
Garland Edwards
RV7 ( in the works)
Garland Edwards
RV7 ( in the works)
