flydjd
Hi all,
Having heard that the Vans Vent SV-5 leaked air I deleted the Vent SV-combo from my kit order and ordered alternative vents....
Does anyone have the vent system drawings that they could post on here or email to me (if there are copyright issues) so that I can "see" how the system should be set up for the fresh air vents....
David
Vents
David,
I'm not sure what part of the system you are needing. The fresh air systems for the -7 kits I have seen are a pretty much hold-your-hand affair. The NACA vent holes are punched at the factory. The placement of the outlet vents is on Drawing 24. In between is just tubing, either 2" SCAT tubing or tubing of your choice.
If your kit doesn't have the cutout for the NACA vent, or you didn't get SV-1s with your kit, order them from Vans. It is the plastic part of the NACA vent. It will come with directions and a cutout template. It has a 2" outlet to attach to any vent tubing. Just make sure the long axis of the vent is parallel to the chord (longeron) of the airplane. Also make sure your vent is high enough to clear any workings or positioning of the rudder pedals. I don't think the position of the NACA vent is that exacting but I believe Van's did work to show that the prepunched location on the -7 skins works well. Also there are a number of -7 builder websites with lots of details and great pictures of how they did it.
The 6 kits don't have any provision for air vents so I patched it together. I got the SV-1 and installed it like the 7s. I also got the SV-3 tubing that Van's sells. I was a bit disappointed because it looks like regular ol' automobile ducting and I am not sure it is any lighter than SCAT tubing. But it will work.
The reason the SV-5s didn't work for some people is that it is made from plastic, probably ABS. The valve plates that stop the airflow aren't machined so they don't match up completely to the inside of the vent. Some people are successful in adding adhesive to make the valves seal. Other people don't like the cheesy plastic look. The builder who gave me a set of SV-5s couldn't make them work and I spent a couple of days in frustration also. I almost threw them away but I think I can take them apart and, with some ingenuity on my lathe, can make them seal.
Some builders don't care about a little air leak but in your location, I think you will want a good seal in the wintertime. If you haven't got your aftermarket outlet vents yet, the best ones I've seen are from Stein Air. I believe they are a full 2''diam not 1.625" like Vans, but also more expensive.
The best thing about the Van's system is it is light weight. On the -6s every ounce counts. Good luck.
Dave A.
6A
sv-5 to sv-6
The leaky part is the SV-5 thing. You just replace it with the nicer (and more costly) SV-6 options from Van's. Other vendors may sell something similar to Van's SV-6.
I threw away my SV-5 vents. The aluminum sv-6 vents are very nice.
Thanks...
David and Don for your replies....
I am about to order the SV-1's, tubing and hose clamps from Van's....
The 7 has pre-punched NACA vents in the fuselage sidewalls but as they say a picture is worth a thousand words !
Does anyone have any website links for pictures of their setups as Dan C's website has gone away !
David
Vents
David,
Here's one I pulled at random
http://www.brownsrv7a.net/gluingonvents.htm
Anytime you want visuals on anything, try Doug's VAF search feature. Use the advanced button.
Or just Google, e.g. "RV-7 + NACA" . Vary the terms and use the plus sign until you get what you want.
I am pretty isolated from support as well and the internet has been a godsend.
sv-5 vent caps
Replacement is the best option for the cheap sv-5 plastic vents to stop leakage. Not at the airport as I write, so I'm not sure of the exact OD on the round sv-5. Should be close to 2".
A simple rubber cap stretched around the OD should fix the leakage temporarily .....if you can find them somewhere.
Has anyone found a simple rubber or vinyl cap with a proper ID?
