cduster
Active Member
OK folks, I've just about exhausted my patience with the MGL iEFIS that came with my plane. Every day its something else and every bit of it requires a very steep learning curve. Have you ever tried to run Linux after coming from Mac OS, well, that's what it feels like to try and learn the MGL system. Its not that its inherently bad, its just a foreign language, so to speak.
If I were to scrap the MGL unit, what could I salvage from my current setup? I know that I'd need the screen (GDU460), the new LRU kit (magnetometer, oat, AHRS), and the GEA24 (engine indication box). Would my existing ammeter shunt/manifold pressure/egt/cht/fuel pressure/oil pressure/oil temp/fuel flow instruments work with "team G"?
I currently have a 430W, G5, GAD29, so that part is covered. I also have a Sandia STX165R remote mode C linked to a echoUAT ADS-B in/out. Will any of that work with the G3X? The STX165R is remote, so it needs to be controlled by the EFIS.
I also have a SL40 and a PS engineering intercom which I'm assuming would all be able to remain.
I'd also have to replace the two autopilot servos but was thinking that I could just run those from the screen and not have to add the external control unit.
Engine Sensor Compatibility
Good Morning,
It is likely that you will be able to re-use most if not all of your existing engine/airframe sensors. Chapter 24 of the G3X Touch Installation Manual lists the specifications for each sensor one by one, so you can match up what you have with what we can support. In general the system is quite flexible with what it can use for these purposes.
You can run G3X Touch autopilot mode selection through the display. The GMC 507 mode controller only replicates the mode selections and knobs available on the G3X Touch display. For these reasons it is optional to include the GMC 507 mode controller, but a lot of people like to include the dedicated controller in their panel.
We do not have any support for that transponder as far as I am aware.
Your G5 will integrate nicely with the G3X Touch system. It will act as a backup ADAHRS source for the GDU. In the rare case that you were to lose the GSU 25, the G5 ADAHRS information would be shared via CAN bus to the G3X Touch display. The G5 and GSU 25 were designed with dissimilar hardware and software engineering to help lessen the likelihood of a single point of failure. The G5 can also be fitted with its own backup battery to make it a true independent backup instrument. It extremely unlikely that you would ever find yourself without a primary flight instrument with this type of installation.
Please feel free to send any other questions our way. You can reach out to us directly at [email protected] if you would like.
Justin
Be ready to sell your STX165R remote Mode C transponder with your MGL equipment or separately. Replace it with a Garmin GTX 32 remote Mode C transponder. Those work great with the G3X Touch and the Echo. The GTX 327 transponder is the same unit but with a faceplate for panel mounting. A GTX 327 could be remotely mounted just as easily as mounted in the panel. The G3X sees no functional difference between the 32 or 327. Both the GTX 32 and 327 are dirt cheap on the used market so don't hesitate to use either.
Then there is no problem keeping your EchoUAT ADS-B in/out but you will need to add a GDL 39/39D/50/52 or equivalent R model of same to get your ADS-B "in" for the G3X system. Those work wonderful on the G3X while also providing data wirelessly to mobile devices. Meanwhile the EchoUAT "in" will remain available for any non-Garmin 3rd party app or device which is nice for you and/or passenger. So with both the Echo amd GDL you will have an aircraft that can supply ADS-B "in" to any portable GPS or mobile device known to man.
Whether you want SXM or not always get the G3X Touch GDU display without SXM. Then if you do ever want that option take that savings and apply it towards the GDL 52 (or R) aforementioned in paragraph above. That will give you the advantage of ADS-B, Attitude and SXM available wirelessly (along with the GDL 52 battery backup) which the SXM version of the GDU cannot provide. Your passenger can also tap into the GDL 52 wireless data stream to navigate or control SXM music, etc....
Jim
Great info Jim. Thanks for taking the time to put that info out there.
I like the thought of switching over to a Garmin mode C and retaining the echoUAT, but for whatever reason, I really hate the idea of giving the larger part of a grand to buy a Garmin product to replicate the echo's ADS-B in functions, not to mention the trouble of mounting and wiring another box and antenna.
Which iEFIS model? Let me know when you remove it, I may be interested (Linux user for 25 years...).
Might be far less expensive to hire someone to teach you how to use and program the iEFIS. There is a learning curve for sure but once you get it the way you want it you might be happy.
You may be underestimating the effort to change systems. No matter how you shake it, changing over to G3X Touch from the MGL will totally mean a lot of work mounting, wiring and probably cutting a new panel. To do it right and reliably. There is no short cut way of doing it. One more box will be a negligible add.
All of this will not be cheap. One rule of thumb states that avionics and flight decks only contribute 20% of their installed cost to the value of the aircraft. The day they are installed new.
So you will take the hit on the MGL equipment, the new Garmin equipment and the labor to remove old and do a new install.
As mentioned above you may well be money ahead to get private MGL tutoring from an experienced user.
I don't know what they could teach me by looking at a black screen. :D
You are, of course, exactly right about the economics of the situation. On the other hand, I am old enough that frustration represents a much higher cost than it did in my youth. Back then, I thought nothing of spending lots of time to save a little money, but now I'd rather spend a little more money and a little less time to accomplish the same goals.
Its the Generation 3 Challenger with the 10.4" screen, ibox, SP-6 compass, SP-7 AHRS, RDAC XF engine monitoring system, two autopilot servos, Sandia STX 165R remote mode c transponder, UAT echoUAT ADS-B in/out with its own SkyFYX WAAS GPS position source.
Currently the screen won't boot up and I'm hoping that it is a software issue that happened during an update that I probably botched. I'm currently waiting on a call from the California MGL contingent to let me know if I should trouble shoot it here, or send it back to them for repair.
PM me a strong offer and I'll go get a screwdriver and some bubble wrap.
I will describe here how to restore a "bricked" iEFIS G3. It is quite simple.
First a bit of background. The G3 uses a Texas instruments processor. This has a built in boot system hard coded by Ti. The first thing it does is look for a file called MLO on a disk. This disk is a Micro-SD card inside your EFIS. If it finds the file it loads it and passes execution to it. MLO is the first bit of "MGL" code that executes and results in a bit of writing on the top left screen.
So if you see that writing - the internal disk is OK and MLO is there. MLO does a few housekeeping things and then looks for the file EXP3.BIN (that is the file you download from our website as update - it contains everything, the operating system, the EFIS application and the default screens). This is expected to be on the internal disk in the root folder (so you would have two files there at minimum to start - MLO and EXP3.BIN.
If EXP3.BIN exists - it gets loaded and you should be fine.
If you only get a black screen (no writing on the top left) - for some reason MLO is not there or the internal SD card has failed (that's rare).
Lucky - the iEFIS can also boot from the external SD card slot and that is the easiest path to get things going. There is one little issue though. Ti in their wisdom insisted that the SD card must have a partition table and the usual disk formatting tools do not do that.
But there are some that do. Most of them require a degree in physics to operate. But there is an easy one on our website. It is RUFUS version 3.8. Rufus is a very nice and easy to use tool written by the Linux community (it runs in Windows so no issue). Here is a link: www.mglavionics.co.za/Firmware/rufus-3.8.exe
It's small and powerful.
Use this to create a SD-Micro card you can boot in the EFIS. When you run the tool please select that you want create a "FREEDOS" bootable disk. It will create a disk with a Microsoft DOS clone (we will not use any of that but it happens to create a partition table).
Note: In Windows 10 you may have to right-click on the rufus file and select "run as administrator".
Now all you need is MLO. Get it here: www.mglavionics.co.za/Firmware/MLO
Copy MLO to your newly formatted FreeDOS SD card (root folder, there will be a few other files there now - just leave them).
Now insert into your EFIS and switch on. It may take a few seconds and then some writing should appear. If the internal disk has failed it will tell you that it has a serious problem and cannot start the internal SSD. In that case the internal card need to be replaced. It is located in a little flip holder. Sometimes it just needs to be taken out and put back (perhaps a bit of corrosion on the contacts) and things work again.
Anyway let's assume all is well and the internal card starts. If just MLO is missing but the internal EXP3.BIN is there - it will be loaded and the system is up and running again - in that case just use the internal file manager to copy the MLO from your external SD card to the internal card and you should be back in business.
If for some reason the internal disk does not have the EXP3.BIN - simply copy it to your SD card (the one you made) and start up again. MLO will copy it to the internal disk and start it without you needing to do anything.
You can also do another trick: You can actually run an external system from your self made SD card. Just rename your EXP3.BIN to EXP3.EXB (for eXternal boot). In this case MLO will load your external EXP3 copy without doing anything to your internal disk.
Now, regardless of how you get your system running again. Please, once everything is in place - make a BACKUP. Your system has a really nice backup function that creates a sector by sector exact identical copy of your internal disk to an external SD card. That means you have a complete clone. There is a document on our website that explains all the things you can do with that.
Direct link: http://www.mglavionics.co.za/Docs/G3 cloning.pdf
Sorry for the technical post but I hope this information can be useful to other G3 users as well.
Rainier
CEO MGL Avionics
Yes, thank you very much. The screen is indeed black with no obvious attempt for the unit to boot. I'll borrow a windows computer and try the detailed step by step and report back.
Well, it seems to have worked. It is still doing some wonky things like not accepting the MLO file and its hit or miss with finding the terrain data. I switched internal cards out and it seem to be functioning much better than it ever has before. Monday, I'll head on over to the office supply store and pick up a new 32 gig verbatim micro-SDHC. Does anyone know if there is an increase in reliability by going with the "premium", "Pro", or "Pro II" versions of that card? The prices are so inexpensive that there is absolutely no reason not to get the absolute best one for the application.
We like using the Verbatim Micro-SD cards. However I once went out to a store and bought whatever I could find from different manufacturers to see how tolerant the CPU is to slight differences between cards.
I did this mostly because of bad experiences with the larger SD cards in the old days.
I found the newer Micro-SD cards are very similar between makes. I have only ever found one that did not work well - that was a no-name brand of uncertain origin.
Don't worry about the class of the card - that only really matters for write speed and even a low class is plenty fast for the EFIS (it never writes to the card unless there is pilot action requiring this such as copy of a file or change a a setting etc). Things go wrong when you write to cards so the EFIS is designed to do as little of that as possible. You can't really damage a card or its structure reading from it.
16GByte cards are more than ample for storage even in the worst case scenario. Don't get anything bigger than 32GByte - there are differences in the card protocols and not all of the larger cards can default to the lower density protocols.
Anyway - very glad you managed to get somewhere with the system.
Rainier
CEO MGL Avionics
