I tried to contact them when I had a EXP Bus issue several months ago and never heard back. We ended up removing the unit (per Stein's recommendation) and replaced it with switch and circuit breakers. I was losing all of my avionics at the most inopportune times.
I hope that you have better luck making contact and a more favorable resolution than I did.
