Driving '67
Friend
I’m working on the control stick interconnect for my 14 and finding it very difficult to install the bearings into the ends. Im only able to get a couple of turns by hand before the bearing thread binds. When I use a bearing install tool the torque required to screw it in is very high. My question is the hole and thread deliberately undercut or should I run a 1/4-28 tap down it?
Watching Vic’s recent webcast and his comments about locknuts and control bearing has got me wondering.
I would run a tap through it then and clean out the threads vs forcing things. Make sure you have not damaged the rod end bearing threads before trying to reinsert them.
Thanks Chris, I only turned the bearing several times before I backed off. I ran the tap down the hole and bearing now fits perfectly.
