D David Burke Member Feb 14, 2023 #1 Anyone have a Vans part number for the angle used to make the control column mount angles ?
6 664781 Well Known Member Feb 15, 2023 #2 ???? Are you talking about the angles that mount to the wing Spar with a bearing in it?
D DavidAhrens Well Known Member Feb 19, 2023 #3 Control column mount hello David; if you still need part number, it is F-633 control column mount. Plans say to make from 2x11/2x1/4 6061T6, each 7 and 1/4 long.
